Carbon Sole Shoes vs. Standard Soles
Couldn’t find much a long the lines of what I’m looking for - found threads stating carbon is better/carbon is more comfy etc.
I know that if you take two pairs of identical shoes; one with carbon soles, the other with plastic soles - the carbon sole is the better “performing” shoe.
Anybody have any idea what this equates to in real world terms? 3% better power transfer? 5%? 0.5%?
I need to get a new pair of shoes before IMAZ - and I’m going to stick with LG ErgoAir (which I have and like), but am debating between the sandard version and the carbon version - it really comes down to how much difference is there between the two?
I just don’t see carbon soles making a difference in power transfer. The pedals should be just at the base of your forefoot, thus meaning that there is no place for power to transfer other than straight down. The sole of the shoe really shouldn’t be bending as you should be applying force through your foot, not on using the show as a lever. Perhaps there is some minimal difference in compression between the soles, but wouldn’t any insole have a greater effect than the actual sole of the show? I’m no engineer, but the idea that a carbon soled shoe will transfer power better than a nylon/plastic sole just doesn’t hold water for me.
Pretty simple concept, really. You want the sole as stiff as possible. Use steel - stiff but heavy. Plastic is plenty stiff if thick enough as well, but then heavy. The carbon soled shoes just achieve this with lighter weight/thickness.
I’m always amazed that triathletes spend all kinds of money on aero this or that, even seat posts, but not on shoes: one of only 3 interfaces with the bike. Plus, a good set of cycling shoes lasts a pretty long time.
I have both and don’t notice a difference.
Do the carbon soles have any added benefit of injury prevention in addition to power transfer? This is of course assuming that the bike position is correct. I am thinking specifically about the Achilles tendon.
Thanks
I have no data to back up my observation, but I can feel an enormous difference between the flex on my carbon soled shoes and my older plastic ones. I’m I faster? can’t tell, but there must be a biomechanical difference.
Feet (+ ankles+ calves+ knees, etc) are not rigid structures.
Carbon is stiffer and lighter. In this application there is no carbon dampening benefit. In fact, when I switched to a carbon sole shoe, I actually had to add a strip of insole pad to the metatarsal head region. No idea how much the stiffness increases wattage.
Thanks
I don’t think so. A significant amount of movement can induce biomechanical “issues” with the foot/ankle, but were are not talking about much here. Are the shoes more efficient with power transfer - yes. How much - I 'dunno. I’ll leave that argument to the engineers. I’ve never seen or heard of an injury that could definitely be attributed to a “flexy” cycling shoe tough.
Recall that Sidi put off making a carbon sole until the last year or so because they thought they would be too stiff.
The one that they finally came out with is a carbon mesh that is engineered to flex.
In concept, the carbon shoe will perform better, but if you are flat footed, it is almost impossible to find a carbon sole with a non built up “flatter arch”. Most carbon soles GIVE ME plantar fasciatis, whereas, most low end plastic soles or MTB soles, are more comfortable and don’t interfere with my natural “gait”. So I can be fast on Carbon soles and injured in a a matter of 500K, or I can go with low end stuff and not have foot issues and be faster overall, cause I can actually do run training, vs hobble around…that’s right, I can ride in those carbon soles, but they mess up my arches so much, that running becomes painful…who would have ever though…for years, I thought it was something I was doing in running…WRONG (at least for me) :slight_smile:
Some points on cycling shoes:
  1. Remember that this is rotating weight, so any savings here are important. Lighter is better and you can make a sole both stiffer and lighter using carbon.
  2. Fit is important. What she fits me and works for me is perhaps not going to work for you. You need to try on a few different brands and models to find what works for you.
  3. To Rod’s point - this is a critical connection point with the bike. It is very worthwhile to spend money here to get the best shoes that you can get. A well taken care of pair of cycling shes will last for years.
  4. There are all kinds of interesting things going on these days with cycling shoe fit. It’s worth while looking into some of them. For example, the Lemond LeWedges - I have found these things to be phenomenal. They have increased foot comfort significantly AND I feel I have a much more positive and powerful connection to the pedals.
