Is anyone else annoyed that many manufactures are laying in a carbon fibre weave as a cosmetic layer in their products? Weave has no structure purposes. I actually prefer the shifting, pearlescent blackness of structural CF.
Then they slap on 1/8" of clearcoat because we’re all convinced our CF needs to be protected. In the end, this is a lot of weight they could cut.
I don’t know why anyone would put an extra layer of carbon in anything. Carbon is not cheap, and an extra layer of layup is a hassle I would rather avoid if I had the choice.
I think you are refering to multi-directional carbon fiber, which has the weave look you are talking about. It does serve a structural purpose, any additional layer of carbon wrap that has been saturated in epoxy will add some amount of structural reinforcement to the bike (or whatever other structure). It also helps to protect the unidirectional fibers, which are usually under a higher tension (and are, perhaps, higher up on the scale of importance in regards to the frames structure).
Unidirectional carbon is lighter (usually stronger but there’s a lot of subjectivity and variable applicability when talking carbon), but harder to work with and make look pretty (generalization). It’s a lot easier to make a bike look pretty by covering the unidirectional wraps with a (slightly heavier, but still structural) mult-idirictional wrap.
A carbon fiber structure relies on all the fibers holding tension together, when fibers are cut, the structure is compromised. You might scoff at the importance of protecting the fibers, but is very important.
What is the significance of the different appearance of the two tubes in the photo up there? How are those different appearances acheived? Is there a performance difference between the two, or are they essentially the same, just a different “pattern” of cosmetic treatment?
don’t quote me on this but the carbonio center tube is a filament wound tube (machine winds a thin tow (carbon tape) around a mandrel with a heat source basically melting the tape onto the formed tube as you go. The felt and the carbonio lubs are carbon cloth either prepreg or dry injected with resin. I believe most manufacturers utilizing cloth layups DO use a thin cosmetic layer if the bike is going to have a nude coat. Or at least they do in the joint areas or anywhere where it might look messy. Also this give the bike a uniform look as we are mainly used to that even looking checkered pattern. On some bikes they just do a paint fade to cover the messy areas. On the old KM40s I actually think the painted bikes were lighter than the nude weave because of no cosmetic over layer of carbon. Obviously the top layer of carbon does provide some protection and added strength, but it’s not as strategically planned or engineered as the rest of the layup.
In addition to the “sexy” factor, I always thought an advantage was a more durable finish. The paint on my Kestrel seems to fall off just by looking at it. I thought paint on carbon has been an issue for several mnfgs.
Most carbon tubes look like the Guru. The look of the Felt is due to a “cosmetic” woven layer added to enhance the looks. Back when you could buy a Kestrel frame painted or bare, the bare were more costly. Many people would pay the upcharge because they figured they would be lighter (no paint). Instead they were heavier due to the extra carbon layer. Or so the story goes.
