what would be the shortest workout (bike, run) or shortest distance race in which you would use this product? is oly too short? half mary too short?
i throw a scoop into my water bottle for oly’s. mix with water or 50/50 water/gato!
if you add a scoop or 2 with Gatorade can you taste it? thus (gatorate mix,1 or 2 scoop of carbo pro)
carb pro has no taste.
No you cant taste it but i would never suggest mixing it with water only, its very disgusting in that form
FYI i only mix 1/4 of the bottle with drink mix, the rest is water and its been fine. I like to keep flavors to a minimum, especially once theyve been out in the sun.
Mix it with nuuns - that way you are not mixing complex carbs with simple sugars which can produce gi distress. Nuuns also have no cals so you wont overload and they provide the elctrolytes.
FWIW I have done this and it works, although last year I switched to infinit becasue I was able to concentrate my mix for an IM into 1 bottle. Carbo Pro doesn’t concentrate well beyond 10scoops. I’ve put 20 scoops of infinit into a bottle before.
