My car was ‘missing’ some so I took my car in today and they replaced the spark plugs. Something I would have done by myself, but I was told the issue probably wasn’t the spark plugs. Last time I’ll listen to my dad for automotive advice ![]()
it’s a place I trust, have taken my car there before for a second opinion and they seem fair.
My truck is a 2000 nissan Xterra has 103000 miles and runs great. I’ve replaced the distributor in the last year and that’s the only thing I’ve ever had to do, until the sparkplugs. They gave me a list of things that need to be done.
AC belt.
Steering belt.
Timing belt
Alternator belt
water pump
thermostat
And said it would $1000 ($600 was labor) to do these things. when it hit 100K miles, I figured that i would have to put about $1500 into the truck in the next year. Which is what this and new brakes which it will need soon) would be. But, if some things don’t need to be done, I’ll wait. For instance, if I can drive it and wait until the AC belt breaks before I replace it and it won’t cost anymore to replace after it’s broken than before, i’ll do that. What about the alternator? If the belt breaks will I have to get a whole new alternator? Or just the belt.
Which of these really need to be done? I’ve been told that if the timing belt goes when you are driving, you’ll need a whole new engine. And you can’t visually check the timing belt. So that one it probably going to be done, as well as the water pump, since you have to take apart the engine for both. The other belts they mentioned are actually starting to crack a little. I’ve lived in dry climates and also moist, humid, ocean climates. I take care of the truck, oil changes every 5K miles, etc. I want to keep the truck running for at least 5 more years so I can say i got my money out of it. If not longer.
I realize that taking it in for 3 different things vs having them do it all at once will probably cost more, and that’s something I’ll consider. I’ll also look into doing some of the easy things myself or having a friend do them for beer.
I am not taking into consideration the truck breaking down and being stranded on the side of the road. I have tow coverage with my insurance for $5 a year and I can deal with that. And access to a company vehicle if I am with out a car for a few days.
I really just want to know what on that list will cost more to fix after it’s broken than if I did it tomorrow as preventative.
