I have run across trouble trying to install a compact crank on my Tri bike (older bike from 2003). It has a braze on front derailleur and there is not enough adjustment room on the bottom to accommodate my new compact crank. Are there any options I have to lower my front derailleur?
Round file, you could use a dremel but there is a chance that it might skip and scratch your frame.
Maurice
I need to lower it close to 1 cm. My bike is at the shop now so I’ll take a look tomorrow, but what if there is not enough room to safely file down 1 cm? It’s a titanium bike if that helps. Pretty tough to remove the old tab and add a new one lower?
Or do they make adapters I could add? I’d like to hear all the possible options. I would really like to get a compact crank on my bike without spending a fortune.
When you get your bike back, post some pictures. If grinding isn’t an option, it might be possible to machine an adapter.
could you fit a band on derailleur ?
It’s an aero seat tube, so I don’t think so. Here is a picture of my bike:
http://img.photobucket.com/albums/v236/Neopian_Knights/bike1.jpg
What type of front derailluer? The SRAM Force and maybe the rival have two different mounting options to account for adjustment options.
An olderish Shimano Ultegra, I believe 6600. I’m definitely willing to upgrade my front derailleur if that will fix the problem.
If it’s at the shop have them test a force front. That’s what I had to use to run a compact crank on my 07 P2.
I tried to run a compact on my wife’s Cervelo Dual and it would not work. I removed it and went back to a standard crank and all is well. Lesson learned. Older bikes were not made for a compact crank.
What derailleur did you try?
I’m thinking the cage will work on the 50 tooth ring but not the 34T?
How about replacing the small ring with a 36T?
I’m going to stop into my LBS tomorrow and chat about trying a Sram force FD, also trying to dremmel down the braze on slot. Besides though options, any options? Why did bikes mount the braze on FD hanger so high? I am in my lowest setting right now for a standard crank. What was the extra vertical movement created for? Really a poor design if you ask me. I would hate to send back the compact crank that I was so excited to install…
Compact cranks were just starting back in 2003, and most all bikes had std cranks.
Suggest as people mentioned above:
- Try another derailleur. Note it doesn’t “need” to get a low as the shimano specs to work. perhaps a newer MTB derailleur would work.
- File the braze on down 3 mm
- Cut off the braze on and put clamp
Another option is swap the rings to 52x36
+1
I have this ´semi-compact´ option on my Canyon, it´s a very good choice.
This!!!
Try 50x36. When I switched to compact cranks on my ancient steel Salsa, I couldn’t move the front derailleur, so I just swapped the 34 for a 36 and it works very well! Caveat - I have Campy 10s chorus but vertical spacing between big ring and little ring should be the same no matter what group you use.
+1 on SRAM Force, it is a common issue for many older frames and I have used the force derailleur on over 10 builds including a QR.
Cheers!
Cassette size? - Looks like you could keep crank and make the gear/ratio change there.
I got mine to work on the same ultegra derailleur on a cervelo dual with fsa compact. It does not have the 1cm recommendation between cage and ring but I still got it to work.
Not sure what kind of rings you have, but fsa make a compact derailleur you might want to try (and return if it doesn’t work). It will get the cage closer to the rings.
