Cannondale SL Hallowgram BB30 Wired SRM Compact Crank set -- $1650 Shipped
For Sale is a COMPLETE SRM system combining the SRM Power Control V wired unit with the world renowned Cannondale SL crank set.
The Cannondale Standard Double Crank set measures 172.5 in length and is BRAND NEW! Rings are 53/39. It is just out of the box and has been paired with its wired SRM unit. It has never been assembled onto a bike or had a chain laid on it. It is a highly sought after crank that IS regarded as one of if not the lightest crank sets in the world.
The SRM wired unit was originally purchased in 2008 and has less than 800 miles on it. The unit just came back (MAY 2010) from the SRM service center with NEW batteries in both the Power Control unit and the crank unit. The system also received a new calibration and slope correction. IN PERFECT WORKING CONDITION! IT WILL BE READY TO GO OUT OF THE BOX WHEN YOU RECEIVE IT! RINGS 53/39
INCLUDED IN THE PURCHASE is everything you see in the pictures: Crank set with all parts required for assembly and interchangeable parts per the riders preference, Power Control V unit w/mounting bracket, AC adapter, and complete owners instruction manual along with CD computer software.
http://i45.tinypic.com/1zegxgw.jpg
http://i49.tinypic.com/oit1xk.jpg
bumping for a POWER boost, any thoughts on the SRM, any questions, comments or other??
Bump for price change, bringing it down, check it out. Brand new crank, fresh service at factory for unit, brand new wire harness, etc. $1800 now
Can I use with bb30 specialized crankset?
I’m pretty sure this is compatible with that crank, but you would need to check with Specialized. Seeing as this set is complete, and new, not really sure if it is justifiable to part with the way this is set-up. I am lowering the asking price $100 to $1800.
Bump to $1700 shipped
No, you can’t use it on the Specialized crank. But you can run the Cannondale crank itself on the Specialized assuming its a BB30 frame set.
LAST price drop before flea-bay. Any comments welcome to why so little interest, price too high, bs offer (it’s legit) or what???
Bumpity bump on the price drop
I already have a complete crank so might be interested in just the SRM stuff (which would allow you to sell the cranks on their own). I am curious though how this is a compact SRM (110 BCD) since SRM just came out with the compact version posted here:
http://www.srm.de/index.php?option=com_content&view=article&id=491%3Aneu-srm-powermeter-cannondale-kompakt&catid=44%3Anews&Itemid=152&lang=it
Many thanks.
The SRM is 2008, while the crank set was just purchased. I did, however make an error in description. The crank is a standard double 53/39 and I am going to edit the description to reflect this correction. The crank was purchased in the last 2 months.
Idle threat on ebay, want to give one more try to sell on ST, make me an offer
