Up for sale is a used 2013 Cannondale CAAD10 Black Inc. frameset and extras. The frame has been used as evidenced by a couple small scuffs in the logos but the frame itself is free from any dents, dings, or scratches. The Black Inc. frameset uses the race-ready CAAD geometry but instead of being painted it is anodized to save as much weight as possible; nearly 1/2 lb! The frameset is also Di2 ONLY, meaning unless you modify the frame you can only run a Di2 groupset on it. Although once you’ve ridden a Di2 group its hard to imagine wanting to go back to mechanical.
My plan was to rebuild the bike with a Di2 6770 front derailleur and shifters and a 6870 11speed rear derailleur for an 11speed Di2 setup. Situation has changed and I no longer have the funds to complete the build. If you are interested in the mix-and-match 11speed Di2 groupset I will provide you with an exact list of what you will need, other wise you can use 6770 Di2 stuff to rebuild to OEM.
The frame is a size 50 with a 52.5cm top tube. (Full geometry can be found here: http://www.cannondale.com/...ouble-crankset-27995) I am 5’8’’ and the frame fits me very well.
Included in the sale is the following:
Cannondale CAAD10 Black Inc Di2 frame (size 50)
Cannondale CAAD10 full carbon fork (stock)
FSA SL-K carbon crankset (gold, 170mm crank arms, 110bcd, 50/34 rings)
FSA K-Force marble carbon handlebar (gold, 42cm width)
FSA OS99 aluminum stem (marble carbon/gold, 110mm, 6*+/-)
Fizik Arione saddle (black/gold, manganese rails)
Shimano Ultegra 6770 Di2 shifters (10 speed)
Specialized 27.2x300mm aluminum seatpost (black, 25mm setback) (Not Pictured)
FSA headset (marble carbon spacers)
BB30 crankset bearings (Not Pictured)
Seatpost collar
Asking $1100 shipped/paypal’d
Pictures here:
http://pittsburgh.craigslist.org/bik/4770370373.html
