Canadians, educate me about cellphone charges
Ok, so I know that you guys get free local landline calls within the same dialling code, but what about cell to landline when in the same code area? Also, do you get free calls to people with the same provider or is that dependent on the plan you are on?
Been a while since I had a Cdn cell plan - but first off, no you do NOT get free landline within an area code. For example, the 905 area code extends from Niagara falls to well north of Toronto - you would easily incur long distance charges even though you are within the 905 region. The phone companies definitely have a catchment area for what is local vs long distance. And in fact, in Toronto they had to split the area code, so there you can dial between two area codes and have it be free. So nothing is ever simple.
That said, much of the rest is determined by your plan, so you purchase your air time usage, and how much long distance/roaming etc you want to have. Land vs cell doesn’t make any difference. I was with Bell Mobility and got a pretty good plan for both Canada and the US.
It all depends on the plan and the carrier - and the plans change by the nanosecond. I use Rogers and have been fairly happy with the coverage and charges, but I’ve never done a piece by piece comparison.
Thanks for that. I suddenly thought about it when I realised that a couple of my Vancouver based friends’ cell number started with 604 the same as their landlines. Given that UK mobiles don’t have a number specific to a geographical location it got me thinking.
I think I will get a pay as you go SIM only offer to start whilst I check out the options.
Cheers, Jim and Dawn.
