Can you "jump into" the middle of a computrainer course
My wife is currently training for IMC and would love to ride portions of the course using her Computrainer. IMC is provided with the computrainer. After reading the manual repeatedly she has yet to find a way to “jump into” the course at a particular location. Is this possible to do this or must she edit the course to create and save the particular portion of the course she wishes to ride?
Thanks for your informed response.
Hugh and Denise
It sounds like you have an older edition of the computrainer program. If you go to the computrainer website there is an program update you can download that will let you start a course at any point you wish. You just type in what mile you want to start the course from and click while the program is starting.
Richard
Yikes that sounds easy. We purchased the unit last year. It has the 3-D capability as well as PC-1. We also have a very old Nintento version (More than 10 years old) that has seen a great deal of use. Can you quote the specific instructions for jumping in or page number that describes them.
Thanks a bunch,
Hugh
go to computrainer.com
click on tech support for Pro 3D
click on software updates
click for latest 3D software update patch
you should end up here:
http://www.computrainer.com/html/improvements_to_3d_v3.htm
I hope that solves your problem,
Richard.
Richard,
Wow, you’re “da man”. thanks so much for the quick and useful info.
Hugh & Denise
Once you have the latest version, use this feature:
Start from X. This little feature will allow you to start any course at some place other than the start. So, if you want to ride only to the top of Richter Pass of the Ironman Canada course, then figure that distance out and enter that distance into the box above the Race Now button. Then, when you are on the race screen you can either press the F1 key once to start as normal, OR as the 3,2,1,GO is counting down press the F1 a SECOND TIME to move you to this new position and restart the timer. This way, if there is a number other than 0.00 in this button, but you didn’t intend to start in the middle – you have control over whether the feature works or not. Pretty cool. Remember, you can save performance files without crossing the finish line, so you should be able to stop and save anywhere after your middle start.
Hopefully it works better for you, but I’ve tried it with the latest updates and it doesn’t work.
