I am going to purchase a 12-27 cassette. I have a 12-23 on my road bike right now. Can I change to 12-27 from 12-23 and use same chain?
It depends on how tight your chain was put on the first time. What does your deraileur do if you shift to the largest cog while on the big chainring? If your chain is a good fit, this shift will pull the rear D quite far forward at a 45 degree angle. If your rear D is more like a 90 degree angle then you probably have plenty of chain. If it does pull pretty far forward it is still usuable but you will need to pay attention to how far up the cogset you shift while in the big chainring.
Chad
I go between a 12-23, 12-25, and 12-27 regularly with no issues.
