Here’s a quote from cyclingnews.com, written by someone (Ric Stern) who infrequently posts on this forum, in response to a similar question:
"The idea that you should not do any intense exercise during the base period is a myth. Some coaches have suggested that low intensity, large volume ‘base’ type work leads to the increased development of capillary density, and that intense work somehow damages these capillaries. However, this is untrue, and a high capillary density is correlated with a high VO2max, which is best trained with intensities that approach and are around VO2max.
Just completing low intensity, large volume work for long periods of time will, not unsurprisingly make you better at cycling slowly for long periods of time! By doing this you would detrain other adaptations that have occurred from earlier in the year (e.g., race specific fitness). While you may not need to train as intensely during the winter as during the summer (although for some riders they should), it’s a good idea to do some moderate and more intense intervals over the winter period to maintain or even increase certain aspects of your fitness.
As regards weight training, it won’t have a great effect on your cycling performance (assuming you do endurance cycling events such as e.g., RR, TT, etc). Primarily, it will increase your sprint power if you increase your muscle cross sectional area, however, this will be at the expense of having a greater mass to lug up hill. Additionally, the increased cross sectional area will likely result in a decreased mitochondrial and capillary density which will result in decreased aerobic capacity. This will likely have a detrimental effect on your cycling.
For most people that I coach I would prescribe a mix of intensities through the majority of the winter. what that mix is, and how intense you should go will be dependent on many factors, including, e.g., time available for training, absolute fitness, relative fitness, the type of races you compete in, etc. Additionally, I would also prescribe various types of endurance work as well (not just ‘LSD’ type work)."
For me this year, training for a 1/2IM, I am doing no LSD work this winter. I am doing shorter trainer rides at a substantial percentage of my CP60, and swim intervals on short rest (4-6 seconds/100yd) near or below my intended race pace.
