Taped tufo elite vs. glue Corsa CX vs. clincher GP3000 comparison.
I just noticed this thread on Clincher/Tufo’s etc. Here are two tests I posted to the bicycletech forum
********** First Test 4/18/2005 ***********
Bike + rider 185lbs
front tire constant clincher GP3000 on cxp30 rim dura-ace hub
3" rollers
Tubular Tufo elite road 23c tubular taped to zipp 404/pt-sl hub
Pressure, avg watts, avg speed
- 115lbs, 199, 19.9
- 160lbs, 201, 20.8
- 210lbs, 200, 22.1
Clincher pt-pro w/cxp33, conti GP3000
4) 115lbs 201 25.4
I can believe 1,2, and 3 but the difference with the clincher is huge!
There might be some calibration issues between the hubs. I suppose I could cross-check them with the computrainer.
Some things I noted:
- The tubular tire warmed up to speed and settled in much quicker than the clincher.
- The clincher never got as hot as the tubular. The tubular got pretty warm.
- The clincher took 40% longer to peak out in speed (warm up).
- The tubular picked up a lot of aluminum from the roller gaining an aluminum sheen. Perhaps this was because the tubular went first and there was AL oxide on the roller from sitting for the last month. However, I have never noticed this when using clincher training tires on the roller.
- The reduced rolling resistance with increased pressure on a smooth surface is consistent with the idea of higher pressure on smooth surfaces such as indoor wooden tracks.
I did the test increasing the pressure each time. A better control would be to go back down decreasing pressure and re-testing. I will test the tubular again to see if I can repeat the results. Once I can repeat them I will pull it off and glue it up for a second series of tests.
It was not too scientific but I am sure I did help conclude that a TT done on rollers with the tufo and tape will be slower than that done w/clinchers…
********** Second Test 5/2/2005 ***************
After using my freshly glued Corsa CX in last weekend’s races (90 mile RR and 50 min crit) I ran another roller rolling resistance test with surprising results.
Bike + rider 185lbs. All tests front tire constant clincher GP3000 on cxp30 rim dura-ace hub 3" rollers.
Corsa CX tubular glued to a Zipp 404 rim using Vittoria Mastik 1 3 thin coats on rim and 2 on tire. PT-SL hub.
- 115lbs, 201, 26.2
Re-run of previous Clincher pt-pro hub w/cxp33, conti GP3000
- 115lbs, 200, 24.2**
** Looking at last night’s file vs. the previous test of the clincher I did not give the clincher as much time to warm up. The 24.2 is comparable to the clincher’s performance at the same point in time in the previous test. I will run again using a longer time to verify.
What needs to be run next is a test of the Tufo Elite with glue to isolate the the tire or the tape. Unfortunately I don’t have the motivation to remove my Corsa CX and glue the Elite.
In the crit last weekend a teammate rolled a Tufo using Tufo extreme tape on a carbon rim. The failure was in the middle - i.e. between the “glue” and the plastic strip not between the sticky stuff and the tire or rim. I would not use the tape in crits.
I was very reluctant to run the test fearing I would have this cloud hanging over tubular wheels if the speed were still down in the 21-22 mph range with the Corsa. I understand there are a lot of issues - RR is a small part of the total resistance the rider has to overcome, a 3" roller is quite a bit different than a flat surface, etc. But who wants to pay extra and go through all the hassle for increased RR? At least now I feel like the tubular if not better (it tested better) is as least the same as a clincher. Now that I have a front / rear Corsa CX I will compare both vs. a front / rear clincher. I might also try a latex tube in the clincher.
Kevin
