Dev P wrote: I would rather do tris and marathons and die early, then sit on my ass and not do these great things and miss out on life.
I agree.
However, I’ve seen lots of people’s hearts, some were athletes on the operating room table with thick, sluggish hearts ravaged by heart disease. But, it’s been a rare case compared to the thin people with cholesterol levels in the low 100’s (they picked the wrong parents), the obese, the diabetics, and the smokers. The currently active athlete getting heart surgery is about as common as the unlucky (accident victims). Then again, one of the reasons we don’t see currently active athletes in the OR, is that their heart disease often curtails their activities for quite a while before they become sick enough to need surgery.
From a strictly physical point of view, thick ventricular walls can cause a bit of a problem for adequate blood flow (more-so in the ventricular septum). It’s harder to get blood deeper and deeper into thick squeezing muscle, for a couple of reasons. Then, if the small vessels that reach deeper into these thicker walls get plugged with platelets, bits of clot, or other debris, the newly irritated muscle cells can send out electrical impulses that can cause an arrhythmia. If you develop an arrhythmia that results in a significantly inadequate pumping action of the heart, you lose consciousness. Depending upon when you lose consciousness (not a good thing to do while driving a car, for example), or depending upon how long an arrhythmia lasts (especially if it is not allowing the heart to move blood adequately): you can quickly become worm-food. More normal ventricular walls and septae don’t have some of the physical characteristics that predispose the person to the decreased blood flow in these wall, and are therefore not as likely to have the small vessel obstruction problem to the same degree.
I make a living stopping the electrical and physical action of the heart, so that a surgeon can operate on an unmoving heart for periods of time (up to a few hours). The thicker-walled hearts are much harder to adequately perfuse in order to sufficiently cool the muscle and deliver the high-potassium solution throughout the entire muscle wall. If the heart begins to “wake up” prematurely, it’s often in these thick-walled areas that were harder to perfuse.
Athletes, like people with certain valvular and/or shunt disease, usually have thicker hearts. A little thicker is OK. A lot thicker isn’t. The more stress the heart is working against, the thicker the ventricles become. If, as an athlete, just as in someone with certain heart disorders, one’s heart is required to work too hard for too long, it can get too thick to be healthy…at least compared to an athlete’s heart that isn’t so thick.
I don’t know where that line in the sand is drawn. I don’t know if it is at 10 hours, or 20 hours, or 40 hours a week at 60%, or 75%, or 85% of Max HR. Probably, the imaginary line is dependent upon the peak and diastolic blood pressures found during exercise in the individual, as well as the duration of exercise. So, if you are hypertensive in spite of your exercise, don’t think you shouldn’t worry about your hypertension. It wouldn’t be a bad idea to check your blood pressure during exercise to make sure it is within normal exercise blood pressure limits.
That’s just the physical heart changes due to exercise…the pollutants one is exposed to by breathing all the fossil-fuel-burning exhaust (hear that SUV owners? ;)) when exercising, as well as all those extra pollutants from the extra food athletes consume, may stress the body, too. The fight or flight response does depress the immune system some. Simple over-use injuries (defined as tearing tissue down faster than it can be rebuilt) can contribute to mal-health, as well as free radical damage from all that increased oxidative chemical reactions.
HOWEVER, if exercise were a drug, it should be the MOST prescribed drug for what ails the human being. Exercise, done in the right way, benefits probably every aspect of the human organism…mentally as well as physically.
I plan to always be exercising to some degree, but, after my first Iron distance race this coming weekend, I’m cutting back to more sane and sustainable exercise workloads. Some of you are suited for longer endurance athletic better than I am. I’m a natural sprinter-type that has moved too far the endurance direction…I think I should let the pendulum swing back a little more toward my natural tendencies, I might even live a little longer, who knows?
