Relatively new and expensive clincher tire with a small hole in it. So small that a butyl tube works fine, but a latex tube blows when past 80 psi. Learned that one the hard way.
Will a tube patch work? I’m guessing it would fail eventually. Is there a consensus on a substance to use to fill this very small hole? Silicone caulk, super glue, anything?
I’ve done this for so long that I’ve been surprised when changing a flat and finding money tucked inside the tire. It works for suprisingly big holes. I’ve also glued a tube patch on the inside but sometimes this makes a lump in the tire
The dollar that bmanners mentioned works great. Ive also used a gel wrapper in a pinch. something that works better than dollar bills and is FREE is to use a peice of tyvek. Get yourself a fedex envelope and cut out a peice to use as a tire patch. You can get decades worth of patches from a single envelope.
This is what I will do. I also cut tire boots from old tires: why buy em?
We had to do this on a ride with a large cut in a buddy’s tire. When we got back to the shop, where I worked weekends at the time, he had a new mechanic/dogboy, put a new tire on. The mechanic brought the dollar out and made sure to give it to the guy in front of me. He asked later if the shop was testing him.
I have used a tube patch before as well. Anything to get you back in!
I wish I’d seen this thread before buying a new tire to replace one that got a nail through it (and the tube, and the rim strip, and the rim bed) on my last ride.
