Can pedal location help with speed on a downhill?
At the risk of sounding like a smartass, how about pedaling down the hill. Unless you are completely spun out, you can still pedal.
There are speeds at which it is counterproductive to pedal. How much power do you think you need to produce to go from, say, 45mph to 46mph?
“At the risk of sounding like a smartass, how about pedaling down the hill. Unless you are completely spun out, you can still pedal”
That’s what I was thinking.
"TDF guys… downhillers… XC mountain bikers… all put one pedal down when cornering for one reason: to weight the outside pedal and lower the center of gravity and corner better (the same thing Moto GP guys are doing when they get off the inside of their bikes in corners). When descending in a relatively straight line they all have pedals horizontal and equally weighted (with the same foot forward that they would use on a skateboard or surfboard) for balance and control. It’s also more aerodynamic because lowering one leg exposes more surface area to the wind.
And if you’re hauling ass downhill your weight better not all be on your saddle regardless of where your legs are… your legs (both or outside one) should always be weighted enough to ever so slightly lift you off the saddle.
Also, as counter-intuitive as it sounds, your grip should be relatively loose (i.e. no death grips) on the bars and you should allow the bike to flow underneath you, if that makes sense."
I agree 100%…all gold.
I agree that it could be counterproductive to pedal at times. I wasn’t trying to say that pedaling down the hill is always the first option. Yes, increasing from 45 to 46mph may require more power expenditure that it’s worth. But if the speed is lower than pedaling may yield some tangible benefits. I was just trying to comment on the fact that everyone was offering up advice on where to position your feet, but nobody seemed to comment that pedaling is an option too.
