Spinergy Rev X. Slightly out of true, I can see it wobble slightly between the front calipers. Any fixes or am I outta luck? Thank St’ers.
Can’t true a Rev X.
bummer…![]()
A Rev X can’t go out of true without being broken. If the hub is intact, and the spokes are intact, it can’t be out of true, can it? Are you sure that it is installed correctly? Take it off the bike and, holding the hub/axle (not the skewer), spin it. Is it wobbling?
I had one go out of true and everything was intact. Can’t the aluminum rim bend a small amount without the carbon breaking?
Good news, you can pick one up on Ebay for less than $100, probably closer to $50 depending on size and age.
good looking. I’ll do a more complete exam
i’m pretty sure its all intact. I’ll try your spin technique
If it’s broken, I’ll sell you one or both of mine…
I’m no mat sci person, but can a carbon rim bend without breaking?
