Can I manually calibrate my PT?
I’m pretty sure I know the answer to this question but I’m going to ask anyway because I’m in a bind. Got a rental sub-9 disc w/PT from somebody and I immediately noticed a power reporting problem. Once zeroed, torque and power looked to be reporting consistent but low (40 - 50w). I checked the calibration number and it says 646. :frowning: There’s the problem. My race is next Sunday. There’s my 2nd problem.
Sure, I might get lucky to get this out to them by Tues/Wed and back in time for my race but I’d rather not take that risk and see if I can manually calibrate it myself. Doesn’t hurt to ask…
Thanks, Chris
Where’d you find the calibration number? What should it be?
Fred
For starters, try the “stomp test” described here:
http://www.midweekclub.ca/powerFAQ.htm
That will let you know if it’s truly off to begin with. Generally Powertaps are right or they’re really, really wrong (like by 150 watts).
-jens
Fred
You have to get into Test Mode from the menu. The zero calibration number should be 512 ± something like 10. So, roughly between 502 and 522. The end of the manual does a good job explaining how to go into test mode in case you don’t know.
Thanks, Chris
-jens
Believe me, I know it’s off. From my experience, the best way to do it is to go into test mode and just check the calibration. The middle line is the zero calibration # and should be set somewhere very close to 512. If it isn’t then it’s calibrated incorrectly. 2nd way is to see if there’s a lot of drift (top line) which means the torque tube needs to be replaced.
I had another wireless PT with a torque tube problem about 2 months ago so I’ve played with this extensively and know it well now.
Thanks, Chris
