i’m on a road bike with STI’s & clip-ons (yeah yeah go ahead ;o))
in a year of cycling i’ve never used my drops so for me they’re surplus to requirements. i figure if i can save a few grams then why the hell not? is this safe to do? specifically on PD Hammer OS (31.8) bars? how far below the bottom of the rubber hood can i cut? do i just cut straight across the bar and plug? has anyone done this taken pics?
i’ve never seen it done before so any help would be great.
Straight enough for what? There is no reason why the ends of a handlebar should be straight. I even cut my steerer tube with a hacksaw and never had any problems with that either.
Quite often when riding on the hoods, you’ll rest part of you hand against the bars beneath the hood. Remember to leave enough room for that. Measure twice, then go nuts with the hacksaw.
Please remember that the bar end plug may need to be well secured, since it’ll be pointing down, and could get knocked out by a large bump/pothole
The weight savings is minimal and why loose another position? Riding down a steep hill with turns is much safer in the drops than on the aero bars.
If you really don’t want them, spend a few bucks on the vision base bar (light, aero, comfortable, affordable) and some bar end shifters and brake levers. You can probably get setup for $100-$120 and still have a road bar as backup.
Is your position bad so you are uncomfortable in the drops? You really need the drops for descents, corners, and sketchy riding. Hit a big bump on your hoods and your hands can come off the bars and crash you. Hit the same bump in the drops and your hands will stay in the drops.
Can you cut it? Sure! Some fixte riders on the cheap cut the drops all together and turn the bars upside down. Voila! bullhorn bars!
If this bike is your road bike that is also used for “regular” road cycling->
Maybe a better idea to leave the drops. Are you uncomfortable in the drops? Try flipping the stem to raise the height of your bars relatively to the height of the seat so that you can actually use the drops ( flip the stem assuming your steerer tube is cut and you dont have spacers ABOVE your stem).
/rant - So many folks are obsessed with how many spacers they have on their road bikes only to get the bars so low that they can’t actually use drops. /rant off
btw—i have done exactly this before, worked fine. The brake levers never move, so you can cut as close to them as you’d like, let the hood cover the exposed bar.
mudflaps, bootsie, roadie…“You can probably get setup for $100-$120”…this cracks me up, i’m in NZ mate…and i was half-joking about the weight savings ;)…“You really need the drops for descents, corners, and sketchy riding”…like i said i’ve ridden a year without touching the things (and yes i’ve ridden plenty of descents, corners and sketchy rides), so i don’t think i really need them, nor will i lose a position if i don’t intend to use it, i imagine the triathletes riding bullhorns/clips & integrated setups are of the same opinion…“If this bike is your road bike that is also used for “regular” road cycling”…it’s a road frame but i don’t do “road” riding per se, no group rides, no road races if that’s what you mean
cyclenut, neil, bryce, roadie again (edit: and jeremy)…thanks for the tips, a few things there i hadn’t thought of - cheers
thanks all for your input, much appreciated. although no-one has confirmed it directly i’ll assume its safe to do on these bars.
These are flipped & chopped road bars on my wifes bike, plenty of miles on NZ’s awesome ‘roads’ without any problems - note the MTB wheels in place of 650’s - thats how good the roads are here!
If you ride shimano drill & ovalise a hole about 2cm or so down from the cut end to run the cable internaly - campag does not work like this at all tho.
easy as - I bought a $20 pair of second hand bars - put the sti’s where you want them & wrap some electrical tape 5 mil above the top of the hoods. Use a hacksaw & cut round the line of the tape to get it straight
drill & ovalise those holes about 2 cm down from the ends (top of pic) - depending on your bars you might have to drill into the cable channels to let the cables out of the bar (middle of pic) - good bars will have the holes already in teh cable channels & cheap ones should be thick enough to drill without worrying about strength. Just gouge the drill up & down to ovalise the holes - maybe sand them a little bit. best to practice this on the discarded bit of tube! You will probably get about a million posts saying that if you drill your bars you are going to die - use common sense, I would never drill a 180 gram coke can thickness bar, but somthing more sturdy will probably be ok. Those holes near the end have next to no leverage put onto them & should see little stress.
The hardest bit will be cutting the cable outers - if you have never done this try a grinder or your lbs. Shove them through the bar & leave about 3 cm sticking out the hole at the end of the bar - this will engage right into the sti lever.
I second the advice to use a pipe cutter. It’ll make a nice, srtraight, clean cut. Yes a hacksaw will do the job, but a pipe cutter will do it better. You can pick one up at Home Depot for less than $10.
