Can golden cheetah do this?
I’ll implement whatever you want, you are probably the only person that will use it!
I’m a simple soul, give me a formula and I’ll code it :slight_smile:
either mph or kph is fine.
Cheers,
MarkTake the high ground: SI man!
Meters and seconds’ where it’s at :wink:
But seriously, there should be a generic formula option: P = Av + Bv^2 + Cv^3
A cool idea is to calibrate a turbo or hydraulic trainer using a (loaner) PM and Aerolab. After a thorough warmup and a highly variable ‘calibration ride’, generating a flat VE will provide the A and C factors, with B=0.
A magnetic trainer might not play well, though.
Indeed. Will look at that. I’m busy breaking out the code from GC to create an opentrainer application – think its time this stuff stood on its own.
Standalone?!
Great. Then it would be cool if there was an entry for flywheel inertia (or virtual mass).
Calibration roll down test…
AndyF alluded to that the Ant+ speed sensor sends very precise wheel revolution data, that gets lost in the typical Garmin units. Maybe you can make better use of the data packages :slight_smile:
Sounds like you have some smart ideas. Send me a PM and we can get a feature list going. Can’t promise will implement it all, but good to start collecting the best ideas.
Alternatively email me, same as my user handle here at gmail.
Sure - we need to add a ‘pace’ metric. I wonder if anyone uses minute-kilometers ?? I’d have thought minute-miles was appropriate even if you prefer metric units ??
I would say it’s the other way around: min/km are more appropriate, even if you use old non-metric units.
For running, even in the US, the shorter distance races are all based on metres and km (100m, 800m, 5k, 10k, etc), so the min/km numbers are more meaningful and easier to calculate with for most races, even if you use miles.
I use minutes per km for pace. Miles are meaningless to me, and for most people outside of the USA and maybe UK.
