Probably been asked 1000 times but…I have a set of blackwell research 50mm rims with a campy freehub body. If I throw a campy cassette on there will it work with my DA RD and bar end shifters?
Work? Yes, but no very well (will jump around under load for example). Easiest workaround is something like a Wheels Manufacturing Cassette (Campy cassette with Shimano spacing) or a jtek shiftmate adapter in the rear derailleur cable (MUCH cheaper).
Excellent, thanks! One more question, in an effort to keep the wheelset interchangeable with my other bike I tried changing freehub bodies but a shimano 10s freehub body does not fit over the axle. Any idea if there is a shimano freehub body that might fit the bill? I was unaware that axle diameters varied…
Don’t know about the Blackwell wheels - will have to check with them, but I would assume they have a Shimano freehub body for it.
Yes it will work if you put your Bar ends on friction instead of index shifting…I run Shimano Shifters on my TT bike with a Campy Drive Train.
Thanks for the help. If anyone knows where to find a shimano freehub body for Blackwell Research 50mm carbon rims please let me know! BR seems to be unresponsive since they shut the doors.
