Campagnolo Gear Ratios Question
Does anyone know the individual tooth numbers for the sprockets of a Campagnolo 11/21 10spd cassette and a Campagnolo 12/23 10spd cassette? Also, are the larger gears supplied as individual sprockets, or as a cluster?
Thanks
fade,
11-21 has the following cogs:
11,12,13,14,15,16,17,18,19 & 21.
12-23 has:
12,13,14,15,16,17,18,19,21 & 23.
The lower end groups, i.e., Veloce or Mirage will have individual cogs. The higher end groups, i.e., Chorus and Record will have the clusters. As far as where this “break” occurs I have no specificc knowledge. Daytona is in the middle of these two groups.
For 10 speed cogs:
Veloce - I’ve had several sets in different combinations and all have had individual cogs.
Centaur has one pair, then eight individual cogs for the highest gears
Record and Chorus have two pairs, then six individual cogs for the highest gears (fewwest teeth), although it seems as though 12-25, 13-26 and 13-29 may have three pairs. I couldn’t find one not mounted to check that.
You can make anything you want if you are willing to play - what is it you are looking for?
What I really want is a close ratio straight through block for TTing to run with a 56x42.
Seems to me that Ben already answered that question for you:
I TT ( as opposed to ITT) with a Campy gruppo and use an 11-21 in back with a 53/42. 56 is a BIG front ring. Can you ride a 56/11? Think Disco is looking for a new TT rider. Seriously, that’s a huge gear. If not I would suggest a smaller front ring and still running the 11-21 in back.
Ric
Currently I TT on a 53/39 with an 11-23. I’m hoping to switch to a 56 (or even 58) 21-21 because that will make the indivdiual gears closer together (FWIW 56x12 is a slightly smaller gear than a 53x11, all else being equal). The maximum gearing is slightly less important to me (though I do pedal downhill, and spin out on the 53x11 in any TTs).
53 isn’t that big, though, IMO. I TT all distances (10 miles to 12hrs) in predominantely 11, 12 and 13. But then, I grind.
I know, but R10C asked me what I wanted…
(at least I refrained from going full-on Jim’ll Fix It on him!)
:wink:
If you’re trying to build a 12-21, you’ll need the 20 from a Veloce junior cassette as your second lowest gear since that’s Campy’s only 20 tooth cog. That means a 21 last cog from a Veloce set as well since all the higher level cassettes are paired at that end. Unfortunately, Campy doesn’t have a Veloce 11-21 so there isn’t the right last position cog. I think you’re stuck with an 11-21. I think this topic was pursued on the www.campyonly.com forum a few months ago with the conclusion that a 12-21 just couldn’t be created.
You could go to someone who does custom Campy compatible stuff such as www.cycle-dynamics.com. It will cost you extra and may take a while.
It was the 56/11 that I was saying is big (although 53/11 is plenty big for me). That’s a lot of gear inches to flat pedal. Push the big gears myself in a TT, rather than being a spinner. If you can get on top of a 56-58/11, that will get you there fast. Would not put those big rings on just to keep from spinning out on descents or to get a 19/20 vs a 19/21. It will just limit your choices in the remainder of the event. Might have you spending most of your time in a 56-58/13-14.
Ric
Fair enough, I just thought the the 11-21 is straight through with the exception of the 21 and therefore the best standard option. Custome is the only way you will get an 11-20 or 12-21.
Oh and you just outed your location or at least your childhood location :wink:
I’m glad you put up this thread. I’m putting a 11/25 on my Campy Record Compact 07. I have an 11/23 now but the shop will switch it out for me.(yes I like to spin!) I have to wait a couple of weeks for it to come in.
PS: This is on my Litespeed Tuscany, not my tri bike.
