CaliMan Update and More Info!
Looks like it is going to be fairly warm and slightly windy. The good news is that on a 10 day, Saturday was part of a cooling trend and was the lowest High of the previous 5 days. Who knows, maybe as it gets a little closer, it will be even cooler :slight_smile:
High: 84°F
Sunnyhttp://image.weather.com/web/common/wxicons/31/32.gif
Wind: From the Southwest at 10 mph
Precip: 0 %
Max. Humidity: 46 %
UV Index: 9 High
Also of note is a change to the bike course:
Click HERE to Check Out Bike Loop 2
Changes:
  • Added an Aerojet cut-through which eliminates the Iron Point / Prairie City Section. Notes a section of 30’ “Turf”? Sounds scary :wink:
  • Reduced the time on White Rock on way to Winfield. Where the turn around is not aparent. Make you wonder if it is prior to Payen?
  • Show the Scott’s Road out and back a little better. Looks like this section will be longer than I rode.
  • Shows Special Needs at White and Sunrise Park Turn Around on Loop Two.
  • On Loop 2 (Full Iron-Distance), they added around a ~7 mile out and back on Douglas.
  • Map is updated with Aid Station Locations.
  • Added more “info” about course and support
Lots of stuff on the Course Page, so I would definitely go check it out if you are racing! Good luck!
T-minus 10 days!!!
one bump
