How do they do that ??? Is there anybody that uses the same set-up ?? ( record10 ?? )
I figure that in order to do it… you need to do a very sharp bend on both cables…
Don’t know what the big deal is. My cables run from the barend shifters along the aerobars to just in front of the base bar then dip down into the frame. No cables sticking out anywhere!! Shifts great…no bad bends!
Hi Rocketman,
Pay a close attention... he´s not using the bar end .... that´s the deal... I don´t wanna use the bar end shifters also ... My problem is on the exit of the cables from the ergopower...
Tks,
Bending the housing is what has to be done(obviously). I did it on my bike… and its works good. I just had to test the “kink” and find the spot where it will work; without the cable hanging up inside the housing. Its a great set-up for technical courses!!!
Drill a slot into the bars so the cables do not have to make such a radical bend.
