A couple of months ago, the LBS had an Lynskey R-430 built with Chorus in for a Demo. With the first pedal strokes, you knew it was a responsive, STIFF, bike and around 15 or less lbs.
Calling out the parts gurus that hang out here, build your STIFFEST bike under 18lbs. Thanks! KW
Complete group weights… Lightest to heaviest.
Sram Red, 2214.3gr
Campag SuperRecord, 2218.9gr
Campag Record 11, 2261gr
Shimano 7900, 2282.7gr
Shimano Di2, 2356.6gr
Say 2,400 for a groupo (you could mix and match or get some lite brakes or cranks to optimize this)
about 2,000 frame and fork (and that’s not a super lite set)
headset, stem, bars, cables, seat and seatpost under 2,000
wheesl, tires, tubes tape, skewers, under 2,000
shouldn’t be that hard to get a bike under 18lbs these days
Mike P. and I smoked over 18 lbs of weed last year.
My Archon is stiff as a board and weighs in at around 14lbs with the 303’s on it.
Given the weight of wheels and groupsets now, it is not that hard to build a stiff bike well under the UCI limit. FWIW I run SRAM Red with a Vuma crank but you could get under 6.8 kilo without a fancy crank and a good 1200g wheelset.
Oh man. I’m not a huge an of Specialized, but the Tarmac is just about as stiff as a bike can get. Throw an SL (maybe not an SL2?), and I’m sure that you could get it to be one stiff, stiff bike.
