Bucking Flisters! Treating them and Inducing Calouses to prevent them?
I have been getting a lot of blisters lately. It interferes with training.
I am getting them in a lot of different places. Right now I have a huge one that was drained and had the overlap skin cut away. Other than just air and rest, how can I accelerate the healing?
Further, I want to prevent myself from ever getting blisters again. Is there anyway I can stimulate callouses to develop on my feet?
I asked a similar question recently and this was the answer. http://www.fixingyourfeet.com/ All of the questions I had were answered by this book. It covers everything from prevention to treatment.
By the way, I think smart feet people agree that calluses only make things worse. It starts with proper fitting shoes. Then, the combination of friction, moisture and heat is your enemy. So eliminate those with the right socks, lubricants, and powders and you prevent blisters. That is at least the simplified version.
In my own research I had been considering Nike Free.
I have been trying new shoes. The problem is that all the new shoes I have been trying have this problem, and that my old shoes that do not have been wearing out and are not made anymore.
Never cut the skin off. New Skin and duct tape does wonders.
So how about just plain New Skin?
If I don’t cut it off, there is this big empty pocket that seems to create friction against the sub-dermal layer (or whatever). And it just seems to get bigger.
Bodyglide. It works really well. I usually put it between my toes or in a few other spots on my feet.
Last summer I started running without socks; that also seemed to toughen up my feet quite a bit.
Gonna burn like a mother…
Do not cut the skin off. Drain them and inject them with Tincture Bezoin. When they peel you off the ceiling, you will have a nice, tough callus form.
inject?
Are you a doctor? That sounds like really good advice… unless you are a sadist who is bucking with me and my flister!
Fixing Your Feet. Vonhoff is the man. End of story!
vonhof.typepad.com/fixingyourfeet
It stings like hell but it works. The tincture bezoin sort of forms a glue that holds the top skin of the blister to the raw skin underneath and it forms a hard callus.
Benzoin Tincture is what Army Medics and Navy Corpsman use to treat blisters in the military. New Skin and Dermabond (aka superglue or crazy glue) will all work but all burn like crazy - makes sense considering some of the inactive ingrediants for New Skin is Acetone and Alcohol.
As for preventing them, I know this sounds weird but i put deodorant on the entire surfaces( don’t forget the tops) of my feet and it helps with preventing the blisters. It was a suggestion from a co-worker who runs marys. Works like a charm when applied right. I can race with out socks and not get blisters. I guess it stops the moisture that causes the friction.
But as of right now, what can I do to the blister on the ball of my foot so I can run tomorrow?
Matt
You have sort of made a mess because you took the skin off - so we are looking a raw skin on the ball of the foot - right? You could put New Skin on it - let me know when you do it - I will put my head out the window and see if I can hear you screaming if the area is really raw. Or, put a clean thin dressing on it and duct tape it down. Or, you could really grease your feet up with Vasoline - that really works sometimes. Okay, I am out of ideas. Just make sure you don’t throw your stride off when you run. Best.
Yes, raw skin.
Will try the nuskin tonight (CVS has it, I hope). Will get a little dressing and duct-tape it as well.
Thanks
Ok - applied a lot of new skin (didn’t hurt to much). Applied a ‘tripple later, non-stick pad’ to the surface and then silver duct tape.
I think if I had done it right when it was raw, the pain would have been bad.
I saw the tincture on the shelf. It reminded me of the bottle of thalidamide my father use to use on my cuts. I remember that being quiet painful.
Everyone always says not to peel them, but I was a gymnast for 14 years and you get lots of blisters on your hands and wrists and we always peeled them open, cleaned them out with a Stridex pad, and then rubbed some chalk on them. If they were bad we’d add some athletic tape. So maybe the solution is to just “rub some dirt on it.” :wink:
That’s as good as its going to get. If your stride is off, please bag the run. Good luck.
you were a gymnast?
hehehe
