[BT] Profile Design Fast Forward seat post: any thoughts?
any thoughts from bike fitters on the “credibility” of this article and if the PD FF seat post worth a shot? i own a road bike, and i was fitted in tri position, w/ aero bar and saddle moved forward. i feel i still need to push the saddle to the front to use more leg power. but my knees will hit the arm pads…
http://www.beginnertriathlete.com/cms/article-detail.asp?articleid=1825
btw, i should mention that when i used the vflow cobbs saddle, my fitter had to turn the seat post by 180 (front/back) to allow for a comfy position, whereas the ism adamo race saddle which i am using now (best i’ve had so far and am pretty satisfied with) can be set-up w/o a pb, except for a need to move it more forward. will tilting the nose down help avoid having knees hitting the arm-pads?
Q: so, to have a proper tri fit on a road bike, which prevails: saddle type or seat post or both or none (ie buy a tri bike and stfu …)?
The problem with that article is that it uses the phrases “position” and “geometry” interchangeably. Position relates to how your body floats in space, generally in relation the the BB. You CAN change your position aboard a road bike with a FF post. Geometry is how the bike is built. You CANNOT change this. Bike geometry can, roughly, be split into two parts - the geometry that affects fit - head tube height, seat tube angle, top tube length, stack, reach. Then there are the things that affect handling - head tube angle, front center, rear center, trail, wheelbase. The geometry that affects position can be worked around with posts, stems, bars, etc. But NOTHING changes the handling characteristics of a bike. Putting a FF post on your road bike doesn’t give it more front center. If you move your position 2cm forward on a road bike, then suddenly you’ve got a ton more weight on the front end. If you then put aerobars on the front end, then you’ve got probably 2x as much weight on the front end as the bike was designed for.
Being able to fit on a bike is one thing. Wanting to ride that bike once you have been fit can be an entirely different matter. That’s the problem with that article on the FF post. It never talks about how the bike will handle once you slapped it on your bike.
