Brightest rear light, fairly reasonable in cost?
I nearly didn’t reply because you asked for the “brightest” rear light, and not the “most visible” (visiblest?!).
Not the brightest, but these are popular around my parts over here in the UK. They are not particularly bright, but they catch the attention of the driver because they are unexpected. You don’t expect to see this shape up ahead, so your brain tells you to slow down until you figure out what you are looking at. At least that’s what I think might happen.
Anyway, I think these are pretty good, especially for commuting in traffic.
http://fibreflare.com/
The Knog Blinder is also bright at $60, but I’ve had many a Knog jelly mount fail in the past.
Any other suggestions for an obnoxiously bright, seatpost-mounted, rechargeable light, under $100?
I’ve got the Knog Blinder (the one with four vertically stacked LEDs) for $40 discounted and it held up fine over the last year. The rubber is a thick, relatively non-stretch variety with seems nowhere near the limit on 27.2 and 30.9mm seatposts. Recharging without a cable is a huge bonus. Visible as fuck, this thing is seizure-inducingly obnoxious and very bright.
I don’t really bike at night so I only use one of these for the front.
http://www.blackburndesign.com/lights/flea-2-0-front-rear-usb-combo.html#.VHNRGPnF8To
We use the light and motion - vis 180 on the seat post and the vis 180 micro on our helmets. You can never have enough blinkies!
Nitecore MH1A + Red Filter = 550 lumen, blinking rear light with usb charging or 1 AA for $70
Another one up front without the filter; these 2 lights served me well last 14 months on daily 40 miles commute
Once you start looking outside “bike” specific light, tons of options open up; much better bang for the bucks
Love the Exposure lights and the Tracer works great. Add a Blackburn flea clip-on to your jersey, and you’re set.
Snagged some Vis 180’s on Chainlove recently at 50% off. Have not used them yet, but purchased them based on reviews.
Exposure Blaze for me. Throws out some serious light, great battery life and very rugged build quality.
Don’t know what the drivers are like in Chicago (I’m in London, they’re fairly dreadful), but if you’re commuting in town you might also want to give consideration to having led lights on your wheels and/or a flashing red/white LED mounted to your helmet. Wheel lights hugely increase visibility from the side, and a flashing helmet light is helpful in traffic and for pedestrians as it can be seen over the top of cars. Noticed a significant decrease in the number of near-misses since I fitted extra lights
The output from that will be much, much less than 550 lumen because white LEDs operate by fluorescence and actually have very little ‘red’ output. If that red filter is at all selective then it’s going to absorb probably about 90% of what went into it.
If you want bright red light, get some Cree 2W XP-E red LEDs and run them at about half rated power (so they last indefinitely)… nobody within 100 feet will be able to look directly at your bike without seeing spots for a while after.
