I’m in need of some brake levers with the cable exit inside of the bar.
I know the Profile Quick Stop levers have this but are there any others?
If your levers don’t have it could you post a reply so I can scratch them from the list?
Also if you have a pair that do and want to sell them, give me a shout.
The new SRAM’s definitely do - very clean mount. Although can be a slight hassle to fit (and hope they don’t loosen), as they need to be tightened up before running the cabling as the cable passes through the same bolt hole.
