Brake Lever and basebar compatibilty
I’m trying to get a new basebar set up and couldnt be more confused with the compatibily issues. I know that vision bars only work with vision brake levers. But do oval concepts brake levers work with the profile design cobra bar? Is there a way to tell if certain levers work with certain bars or are they all compatible with each other? Thanks
I had this issue with Sram levers and a Bontrager aero setup. I had to find levers that had an external routing capability with that aero setup. Make sure that whichever levers and aerobar you get are externally or internally compatible. As for which brands fit which brands, I can’t help you. Good luck.
