I am looking to finish a few bikes over the winter and was looking for options other than Nokon’s for the gear and brake housings. What is out there that is light and does not cost a small fortune? Are the Delta Aztec Powerlines any good?
OEM cables…either Campy or Shimano…I promise they will work and you wont notice the weight.
Not looking for OEM brake cables as I would like to upgrade the cable housings to something that A) will last longer and not rust B) will be able to do tighter bends so that I can run both my cables under the bar tape while running Shimano C) looks better and is lighter than OEM
Our time trial bikes came with Nokon Cables probably due to internal cable runs/routing as well as the tight bends for routing with aerobars. On our road bikes, we use Jagwire Racer cables which have Kevlar-reinforced housing and stainless cables - http://www.biketiresdirect.com/productdetail.asp?p=JBRCS&tnum=569961&c=759506
