Bottom Bracket Installation Help Needed
I’m installing an FSA MegaExo bottom bracket in a 2008 P3. Do I need to use any of the 2.5mm spacers to shim the bearings?
Thanks!
No, you should have to use any of the shims. If there is play in the crank once you get it installed then you could put one or two shims in.
Thanks Darrell
