Boston Marathon Tips
I ran last year and had the time of my life. I complied a list of tips from numerous sources. You may or may not find some/all of these useful.
Enjoy your time in Baa-stin!
Wear a watch with a countdown timer set to your desired pace. It will beep as you near every mile mark, which helps keep things on schedule.
Note: All day on marathon day, flashing your official bib number lands you a free T ride.
Also in your gear bag, pack some warm stuff for after the marathon. At a minimum, you want hat, sweatshirt, warm pants, change of socks. Body Glide
Take a poncho or a large plastic garbage bag and cut a hole in it for your head in case race morning is wet. Take this to the race start. If it isn’t raining, at least you’ll have something to sit on.
Bring a snack and a drink to the race start area. You’ll most likely get to the starting area two hours early, and you’ll be getting hungry well before the noon start.
Remember, there are stations on BOTH sides of the road – first on the right, then on the left. If you skip the right (where everyone goes), you can get some on the left.
If you’re like me and you BYOG (Bring Your Own Gu), try pinning your gel packets to your shorts waistband, then flip them inside so they don’t flop around. They only hand out Gu at mile 17 and that’s just too late for me.
Finish line. You can always take the T, but Copley station is closed and you have to walk to Arlington. Avoid the Copley Square T (it’s closed), and go to Arlington Street, the Hynes Convention Center, or Back Bay Station. And try to stay awake for a postrace party.
I have to warn you that miles 22-25 are pretty boring.
Miles 0-2.5:
From an initial elevation of 472 feet, Route 135 drops like a roller coaster as it rambles into Ashland.The gnarliest section of the descent comes in the first 0.6 of a mile, but Boston’s strict seeding system, the size of its field, and the narrow road should help prevent you from careening downhill too fast. This is a good thing, so don’t fight it. Stay in the middle third of the road and let the jackrabbits sprint along the edges. You’ll get your chance to pass them later.
Miles 2.5-5:
The course continues to lose altitude through this stretch. Resist the temptation to “Bank” minutes for the second half of the race-you’ll lose twice as many when you wind up walking on Beacon Street before the finish. At the same time, avoid braking so hard you expend precious energy reining in your strides.
Miles 5-7.5:
Around the 10-K mark in Framingham, the course traverses the first of seven sets of railroad tracks. By now, Route 135 has flattened out, allowing runners to find a consistent rhythm. If you’ve ignored our advice and gone out too fast, when you hit Framingham, you need to settle in. “The mile splits you’d planned, those are what you should be running now,”
Miles 7.5-12.5:
The course undulates as it skirts Lake Cochituate and proceeds into downtown Natick. “Some of the grade changes are imperceptible, but they do help you,” "But if you keep the same cadence and the same heart rate, you’ll be okay. Wellesley College, mile 12.5.
Miles 15-16.5:
On its way into Newton Lower Falls, Route 135 plummets 150 feet in a half mile, the steepest drop since the opening plunge out of Hopkinton. “It’s a terrible hill,” noting that what makes it so troublesome is the punishing haul up the bridge over Route 128 that immediately follows.
Miles 16.5-17.5:
“If you’re under pace, this is the point to really slow it down and regroup, and make sure you’re truly getting ready for the last hills,” Pieroni says. Anyone who feels their legs fading here should “go to their arms,” suggests Rainsberger. Driving your elbows back a bit harder than normal helps bring up your knees. “And that’s going to spread out the workload.”
Entering the 17th mile, you’ll find volunteers distributing Power Gel on both sides of the course.
Miles 17.5-21:
Newton Fire Station Here we go: Take a deep breath, set your eyes on the road ahead, and motor on, tackling the slopes one at a time as you start up the series of rises that ends with the famous Heartbreak Hill. “The first one is pretty long, but it has the gentlest grade,” The second hill rears up just past the Johnny Kelley statue-on the left side of the street, opposite Newton City Hall-and leads to a short, level patch of road that fools some fatigue-addled runners into thinking the worst is over, when Heartbreak proper still looms.
Miles 22-25: are pretty boring
Before entering Cleveland Circle at mile 22, the race turns abruptly right onto Chestnut Hill Avenue, then left 300 yards later onto Beacon Street. By mile 23, you’ll be descending steadily; in the twenty-fourth, the downward pitch becomes even more pronounced.
If you’re still feeling good, “the course is finally sweet to you at the end,” Rodgers says. “It gives you all this good downhill, and you can just glide.” If you’re struggling, Rainsberger advises taking things a few shuffling steps at a time. “Break it down into smaller sums. You can see the darn CITGO sign forever, so don’t look for that. Look for the next water station or mile marker.” As you approach Kenmore Square, beware the Mass. Pike overpass near Fenway Park. It’s just a bump, really, but it won’t seem like that now.
Landmark: Cemetery Mile, mile 23. "People get to the top of Heartbreak and they say, ‘Damn, I made it!’"Meyer says. “Then they go charging down the hill to Boston College, and then their legs are finished.” After crossing Lake Street, anyone who commits that error will be left to suffer in relative solitude.
Miles 25-26.2:
Near mile 25 and the CITGO sign. A straight shot down Common- wealth Avenue leads you to a right onto Hereford Street and a final short incline before hooking a left onto Boylston. Keep the legs churning and the arms swinging. And most of all, soak in the Olympian roar-and the view of the finish-once you make that turn. “You’ve reached the point of no return,” McGillivray says. No matter what the race clock reads, “you can claim victory now.”
Here’s what I have heard - if you really run Boston your legs will be more beat-up and wrecked than after any other marathon that you do.
Great tips! I have done it 16 times - twice as a runner then fourteen times in a wheelchair - and I’m W27 this year going for finish #17. Just e-mailed a friend who is running it for the first time a few tips (from memory) and thought I’d share here, too. Good luck.
OK, here’s a quick course breakdown -
Mile 1 - Massive downhill, stay in control, easy on legs, don’t get too excited. Enjoy the house that blasts the Rocky theme just before mile marker 1 on the first little uphill.
1st 5k - still downhill, you’ll feel like the course is easy but save yourself.
Mile 6 - Coming into Framingham it finally flattens out a bit. Might be windy so draft behind someone bigger and/or stay to the side of the road where it is protected depending on conditions and wind direction.
Mile 6 - 9 - Relatively flat, get on pace, check your legs and nutrition, stay lose.
Mile 9 - 11 - Slightly gradual uphill. You will see it as flat but feel otherwise, especially if a full or partial headwind.
Mile 11 - half - Coming into Wellesley and Wellesley College - Enjoy the scenery and towns, crowds, etc. Running through the “scream tunnel” at Wellesley College will lift you emotionally like you’ve never imagined. Seize the energy and find inner strength.
Mile 15 - 16 - BIGGEST downhill on the course to the lowest elevation on the course (except for the finish line). Be careful here and do not tighten up!
Mile 16 - 16.5 - 1st tester of the course…hill/bridge ove the highway. The race begins here! I call this Boston’s “Pay and Save Hill” (like early in the Hawaii Ironman run).
Mile 17.5 - Turn 45 degree right at the fire station and welcome to the hills! The first hill in front of you (as well as the last one between 20 and 21) are the longest and steepest. (Emotions boil over here — I literally scream “Hooray for the hills, bring 'em on” and then fight back tears). It’s a crazy loud scene! Pace yourself up this hill…push a bit ONLY to test your legs…and enjoy the crowds. This is where your training will pay off. NO NEGATIVE FEELINGS OR DOUBTS ALLOWED!
Mile 18 - 19 - This is actually a downhill section of the Newton Hills…recover, hydrate, eat.
Miles 19 - 21 - This is the Boston Marathon RIGHT HERE. It is 2 miles long. Embrace the pain of the climbs.
Miles 21 - 23 - Downhill sections as you enter the city, pass Boston College, the Circle, etc. Have fun with the street cars that run along the course and enjoy the drunken college kids and post grads hanging out of windows. You’ll see the “Citgo” sign for the first time but remember it is still 4 miles away. Find your reserves here. This part is mentally tough for runners because your body is feeling the hills and there are still more miles to go. It’s not over yet.
Be aware that the temperatures and/or wind may change here as you are now in the city close to the water. If it is cold, be aware that your body may start to tighten up from the weather as well as the hills.
Miles 24 - 25 - The course flattens out here…let it out!
Mile 25 to the finish - Enjoy running down Commonwealth Ave and seeing the brownstones and blossoms. Turn right onto Hereford Street - 1 quick block uphill - then left onto Boylston. (Emotions will boil over again). Congrats!
I ran the race last year and had a great time, actually ran a PR. I would only add to the above lists to bring plenty of warm clothes for* before* the race and something to read. I was a total rookie and didn’t bring a thing.
It was a long morning.
-Jeff
Here are my tips on how to run Boston:
In the starting corral: Remind yourself you are NOT going to try to run with your friend Carlos this year because he always goes out too fast. Even though you know you are in better shape than he is, he’s a race day guy. You are not
Mile 1: Run with Carlos
Mile 2: Run with Carlos
Mile 3: Realize that if you run with Carlos anymore you are going to completely blow your marathon and tell yourself to back off.
Mile 4: Run with Carlos
Mile 5: Run with Carlos
Mile 6: Run with Carlos and start to feel tired
Miles 7 - 10: Find yourself forced to let Carlos slip away. See your pace drop a few seconds per mile
Miles 11-12: Struggle through Natick into Wellesley.
Mile 13: Do not enjoy yourself as you go by the Wellesley College women because you know you are already starting to have to work for this pace
Halfway: See your split in Wellesley. Realize that the second half will not be anywhere near that fast
Mile 14-16: Tell yourself you are going to get back up pace and make a big push to do so. See your pace stay the same or slow a bit. Run by the house you grew up in. Wish you could hop off the course there and go home but nobody you know lives there anymore.
Mile 17: Hit the wall. Hard. Watch your pace drop by 1 full minute per mile here, never to come back down. Try to take the Gu they hand out but find yourself unable to consume it.
Mile 18: Think maybe you can recover from the wall until you make a right turn at the fire station
Mile 19-21. Suffer horrendously. Run by the members of your running club staffing the water stop at 30k. See them all have this concerned look on their faces as you struggle by
Miles 22 - 26. Haze of pain and delerium
Last 0.2 See the finish line and realize that you can not move your body any faster than a shuffle, even down Boylston St
Afterwards: Tell yourself you are done with Boston for good, you will never run it well and who cares
Day after: Start planning next year’s Boston.
