Like New-Worn 1 time Bont Sub 8 shoes. This are Speedplay specific so the cleat bolts directly onto the shoes, resulting in a lower stack height. These have been worn once for about 40 miles. 150 shipped in the US.
Comfort
The Bont Sub-8 Shoe is 100% fully moldeable, so there isn’t much to say about comfort. You can heat and mold this shoe as many times as you would like until you get it perfect. The very light weight (225 grams) as well as the low stack height not only add to the comfort, but your speed as well.
Bont’s heat molding process is one of the simplest in the industry. Bont has developed a resin that requires very low temperatures and hardens back quickly. The process is very simple. You simply heat the oven to 160 F (not any higher… 140 F will even do the trick), put the shoes in for 20 min, remove them, let them cool a bit, then place your feet in, strap them up and let them fully cool. You can see detailed instructions as well as a video here.
http://i59.tinypic.com/x3vfcz.jpg
http://i61.tinypic.com/xptpbc.jpg
