Body Weight vs. Composition
so after a year off from racing and serious training, I’m beginning another training program. Not suprisingly, I’ve packed on a bit more pudge on my “well insulated” self over the past year.
I’m looking at ways to track my progress (which I finds really helps motivate me) - I’ve found that I cant really rely on body weight since Im also supplementiing my tri-training with weights and strength training and tend to bulk up pretty quickly. So I was looking at the Tanita body fat/composition monitors…or similar devices
Has anyone used one of them? Good experience/bad experience? Other products I should consider?
You are better off just “eyeballing it” or just going with how your clothes fits. Tanita scale is not that accurate.
Mike
Edit: Here is a study: http://www.ajcn.org/cgi/reprint/81/1/74 that shows pretty good accuracy of the Tanita scale if your bodyfat is between 20-30%. If you are less than 20% or more than 30%, the Tanita was much less accurate. So…it depends I guess…
Here is my story with the Tanita, 16 weeks ago 187lbs fat and i mean outta shape 2years of ZERO’s. Then i followed that weight in with 4 weeks of running and 16 weeks of serious weights and more running. I am in ALLOT better shape and feel fabulous. SO i do the scan on the tanita again, my weight is 187lbs still prob du to the weights the FIRST time in my life ever lifting and have even done a max strenght phase in there. SO because i was the same WEIGHT the tanita scale spit out the EXACT same numbers, i mean with in decimal points.
SO i think they junk, now all i use to gauge myself is body comp in the mirror and my MAF tests.
tfun~
I just found a neat online site that allows you to track your body weight, all the food you eat, exercise you do, etc.
It spits out neat reports showing calories burned versus eaten, goal weight, nutrients, etc.
www.fitday.com
This post might help:
http://forum.slowtwitch.com/gforum.cgi?post=1138205;search_string=toy;#1138205
It was up here recently. I haven’t really read the posts, just remembered that it was a topic of discussion.
Jodi
They aren’t entirely accurate, but most people don’t use them properly and make it worse. You need to weigh yourself while controlling as many variables as possible. Time of day/time since last workout/time since last meal, etc. The best thing to do is plan a specific time each week, don’t eat or work out for 4 hours prior and make sure it’s midday or later. I have used this scale for several months. I don’t think it is terribly accurate as it reports between 20% and 22% which to me seems high, but during IM training it consistently dropped toa low of 15%. Now I would be willing to bet I am more like 16% normally and dropped to about 10%, but maybe its just wishful thinking. The point is it works for what I expect it to do.
I would not use the Tanita either, the last time I did it was way off. If it is available I would use underwater weighing($$$). If you are near a university they sometimes can do it, depends on how serious you are about the bodyfat%. Otherwise I would just go with how you look and feel. Scales can be dangerous. Good luck.
I know this thread is old, but I just got an awakening that fits this topic.
I have a Tanita that I use on a regular basis and have always assumed that it is 5 to 8% off. I don’t know the error estimate in those things, but BIA is somewhere around there. The one thing that I do like about it is that it seems to give consistent results. It varies based upon my hydration levels, but if my H20 % is similar to the day before - the % body fat is very similar.
I recently had my body fat % taken in an Underwater Tank at the university and just got the results today. The UWW gave me a % body fat of 17.8%. The interesting thing for me is that I used the Tanita on the same day and got 18.3% on it.
Yikes is my first thought. I’ve never tested above 8% when going underwater, mostly in the 5 to 7 range (from memory anyway). But that was 6 years ago. I am now carrying about 8-10 pounds more than normal?
I realize this is a sample of n=1 , but interesting non-the-less. I guess I can’t just dismiss the Tanita all the time now.
I do know that by using the “look in mirror” test, I don’t seem like I’m carrying extra fat. In fact, I had assumed that most of the 8 to 10 pounds extra I’m carrying was due to the way above average amount of swimming I have been doing.
The most interesting thing for me was this quote from my results “The reccommended percent of fat for males your age is 15%. Your fat percentage was calculated to be 17.8% which places you above the levels of a healthy individual. To reach your ideal weight 134.2 lbs. will require a loss of 4.6 lbs of fat.”
After seeing that statement, I think the message in “The Obesity Myth” is ringing even more loud in my mind. I may not be the picture of health, but of all the things that are unhealthy in my life (stress, diet, etc.) I’ve never considered my weight one of the “unhealthy” aspects. At 138 pounds (and 5’ 6.5") I’m still not too worried.
My problem with Tanita is that it tells me I am too lean!! Every time I test myself on it (and it’s one of the most expensive models in the gym) it tells me something around 5.5 to 7 %. I weigh 158 pounds for a frame of 5’9 and medium built. A fellow of mine told me that it is not too far off based on my heigh my waist size (29") and my chest (36"). I don’t have a particularly flaby spot, but I don’t think I am that lean either, because I don’t have a well defined six pack and such. Now this is somewhat important to me, because I have been trying to lose weight (5 to 10 lbs) and if this number is correct I would be losing a lot of muscle mass (which I don’t mind that much if it is from the chest and biceps I built in weight training).
If the Tanita has athlete mode and you can program it for your height and age, you should be able to get a more acurate reading. My understanding is that the Tanitas which do not have athlete mode are not going to be effective for most of the population here on ST.
I think it would be hard for a gym Tanita to give an accurate reading—how do you program it for you each time?
The one I have has athlete mode and while I haven’t referenced it with another form of body fat test, it seems pretty accurate.
It has athlete mode, and it is programmable. Everytime you do a measurment you go through four or five steps. It is the most advanced one Tanita makes.
