Bmc time machine (1)
What are your thoughts on a time machine vs a shiv
In a fight?
Two very different geometries… if one fits you well, not likely the other one will… get a bike fit first and then buy the bike that fits you the best. You’re looking at some pretty serious $, so don’t waste it on an ill-fitting bike…
I chose a bmc tm01 since I was going to go di2. It has better di2 integration. Eyeball windtunnel says it might be faster with the integrated brakes. Its also a light frame compared to the other superbikes.
Make the investment into either the Retul Muve or the Guru fit system. Take the known geometries, for both the Shiv and BMC, and have the fitter input those numbers and work from there. You might even find out the real frame your looking for is neither of these. This would be the closest you’ll come to knowing how each frame differs in both pros and cons. I too looked at the BMC TT model, but I just can’t get behind the horizontal dropout thing. But that might be it’s own thread for another time.
