I have been considering buying an Accusport blood lactate analyzer to use as a training tool. The main purpose would be to more accurately measure my LT and other training zones. I did some research on them and from what I found, the Accusport analyzer does not accurately measure blood lactate concentrations and is not a reliable way to predict LT.
Here is the main article published by the Australian Institute of Sport that spelled it out for me:
http://www.ausport.gov.au/fulltext/1999/triathlon/david.bishop.pdf
I interpreted the study to read that while the Accusport results had a high correlation with the lab equipment used for the benchmark, the Accusport unit consistently (95% of the time) under-reported blood lactate concentrations. This under-reporting would lead the coach using it to prescribe higher than optimal heart rate training zones. While I could try and statistically correct for the under-reporting from the Accusport unit, I felt that by changing the results I would introduce more noise into the measuring process. In the end, I decided that introducing the Accusport measuring process to my tests would not improve on my existing methods of a combination of Conconi test and a 30 minute time trial.
Has anyone else researched this tool? Could coaches who are using them comment on the study I referenced?
Cheers,
MK
