Bikes with a tight rear wheel cut out
For those of you riding bikes with a tight rear wheel cut out (i.e. Cervelo P3 or P2 and others) what happens if you ride through some debris on the road and stuff gets between the frame and the wheel? Does your rear wheel lock up? Can you ride through it if it is a twig or something lodged in the space between the wheel and frame? Do leaves cause any problems if they get in there?
Never had a problem with my P2K. Something would have to stick to the wheel all the way round and get past the seatstays (which rules out twigs pretty much). I don’t run my training wheel snugged that tight anyway, you only need to do that for your race wheels.
Never had a problem w/ my P3 in 5 years. Every once in a while you do hear something zip through there but it always goes all the way through the cutout. It’s usually a leaf or the like.
