Bike Stem To Handlebars Question
I’m going to pull out my profile Aerobars, and buy a new set of regular road handlebars. My stem is a 31.7 Ritchey WCS. That’s the diameter the owner says. However most handlebar diameters are 31.8, for threadless. Deda makes a 31.7 but you have to buy their stem, they say.
I haven’t bought any 31.8 handlebars out there, but, here’s my question, can you put in a 31.8 handlebar into a 31.7 Ritchey WSC stem, 2003. Will the screws unloosen or open up in a 31.7 threadless stem to clamp down on a 31.8 handlebar. Even if you could do it, is it advisable to do it, given the 1 centimeter difference.
I went up to Ritchey logic, and the stems for the one I have are now 31.8. I honestly don’t know if mine is 31.7 or 31.8, he said 31.7. Did Ritchey change in 2003-2004, to go to a 31.8 stem.
The difference between 31.8 and 31.7 is only 1/10 of a mm–a very small measure, considering the general tolerances used in bicycle components. The two are basically interchangeable for bars and stems.
However, I don’t know which profile aerobars you got, but check to be sure THEY are compatible, as most are made for 26.0 handlebars. Only a few of the very newest ones are designed to fit 31.8 bars without adaptors.
Deda handlebars are officially listed as 31.75mm.
Ritchey’s stems are compatible with 31.7 and 31.8 bars, just as their conventional road clamps fit 25.8 and 26.0mm
-Dave
