Bike maintenance (4)
New carbon bike, how does everyone maintain their bike before and after a ride. What do you check over before the ride and what do you check and what do you clean after a short ride, long ride, clean and dirty conditions?
Buddy go look at this…
http://www.bikesportmichigan.com/bikes/maintsched.shtml
Perfect, thanks!
Awesome, I just did a search to find the exact same thing.
Thanks
This is a very well planned schedule. One thing I would add is to clean the frame with pledge as ogten as needed. Pledge is a wax based cleaner so it will leave a nice coat of wax on your frame. Also it does not contain water. I see the mechanics at the Tours completely hosing down the bikes. I don’t really trust my maintenance skills enough to do this often.
After long rides & races, or at least weekly, I hose the bike down (gently), spray it with Pedro’s Green Fizz all over, brush it with a big bushy bike brush (say that fast), rinse, and wipe with paper towels. That gets all the road grime, sports drink, bugs, etc. off everything but the drivetrain which I don’t hit with that brush.
On the bike repair stand I use the Park chain cleaner to clean the chain with citrus degreaser, then wipe the chain with lots of paper towels until they’re black. Take the rear wheel off and brush the cassette with citrus degreaser and “floss” with folded paper towels. Put rear wheel back on. Lube chain with White Lightning wax lube and let dry.
Use Tri Flow to lube all pivot points: FD, RD, brake pivots, pedal pivots, RD pulleys, and shifter levers. Check brake pads and brake alignment. Check shifting and adjust as necessary.
After rides in the rain I will also lube the cable housings with Tri flow using a tool I got @ a motorcycle shop.
Makes the bike look & ride like new! Like they say, take care of your gear and it will take care of you.
Is the pledge good on matte carbon frames or just glossy ones? Thanks.
I would think that it would be fine. My frame does have clearcoat but I do have attack TT bars that are nude carbon. I have used pledge on them many times and everything seems fine.
There are also some bike-specific waxes you can put on your bike- my fav is “Bike Lust”. Don’t know if they’re better than Pledge, but then I don’t ride a wooden bike!
