Bike Fitters out there - Seat pointing up / down or flat?
What are the differences in riding a seat that has its nose SLIGHTLY pointing up, down or Flat? I switched frames from a 78 degree to 76, and seat´s (Fizik Aliante) nose was 0,5cm behind BB, and now is 1cm behind BB (can´t get any further), but adjusting the seat on the new bike I thought that a slightly pointing down seat (almost flat, you got the idea) would allow me to ride on its nose and sounds more confortable. I´ve always noticed many Pros and Fast fellas are riding almost falling off their bikes as they are “nose seated”
Well, this is getting confused, I would like to know the differences is fitting, how the seat can affect things like power, aerodynamics, “crotch” and back confort, etc
Thanks,
I was under the impression the pro’s rode on the front of their seats because they couldn’t get it further forward.
jaretj
I’m not a bike fitter, but I’ve stayed at a Holiday Inn Express.
I make it a point to attend every Blue Competition sponsored athlete’s FIST bike fit. I’ve noticed a few trends with the FIST fitter I hire:
  • The rider is never on the nose. Rider is seated “Normally” on the saddle
  • The saddle is tipped ever so slightly up (0.5 - 1 degree)
  • The seat post clamp is in the middle of the saddle rails +/- 2 or 3 mm (T14 - 76, 78 or 80 degree position)
  • The fitter is using SpinScan help determine optimum power & comfort.
  • My impression of the bike fit is that the riders back is parallel to the ground
  • The riders final comments are without exception that they are comfortable even at 81 degrees (Avg. is 78.75)
  • Hip angles, torso/arm angles are pretty much the same regardless of final seat tube angle.
I was under the impression that rider’s riding on the nose was because they can’t get the seat post forward enough. If I was to ride on the nose I would want to make sure I had already had all the kids I wanted or had made donations to the sperm bank :slight_smile:
I hope in some vague way I’ve addressed your questions
