Bike fit questions
Howdy,
I’ve been lurking here for a while and have really appreciated the great advice and depth of expertise, so I thought I would ask for help. I have been to 3 different LBS and have received 3 different size recommendations (all for the same bike).
The fit I currently trust the most puts me on a bike with a 52cm ST (C/T), a 51.5 TT (C/C), and a ST angle of 76.3. I’m 5’10” (180 cm) with a 33” inseam (84 cm). I’m 140 pounds, fairly flexible, strong core, and my arms are short (in relation to the rest of my body). Unfortunately, not a single LBS has a 52 cm tri bike in stock for me to try.
My questions are:
Does this sizing make any sense? My initial reaction was – man that seems awfully small. Assuming that the above size makes sense, what frames/bikes should I be looking at? I’ll be competing in oly distance this season, ½ IM next, and if all goes well IM after that.
Thanks for the help,
slim
It is certainly in the realm of possible. I’m 5’9" with normal proportions and I ride a 52cm bike with a 75 degree seat angle with the seat all the way forward and a 100mm stem (ie I could easily get away with a 51cm bike).
It does sound small, in fact, my LBS thought I was nuts, until he saw me on the bike after I set it up. I walked out of another LBS after I explained why I needed a 52 and not a 56 (like I had been riding, with a zero set back post and saddle all the way forward and 90mm stem) and they replied right back that a 52 would be too small. Whatever!
I’d venture to guess that 50% of ALL non-elite/non-pro triathletes are on bikes that are too big.
Heck, my wife is 5’7" but she needs an XS (EXTRA-SMALL) TT frame. What the heck do actual small people ride?
The 2nd LBS was hilarious. I carefully explained to the guy that I was riding a 56 with a zero set back post, saddle all the forward, and a 90mm stem. He responded. Oh we could fit you on a 56 by just adjusting the saddle and stem length. What? How can you get a smaller cockpit that what I already had? A 50mm stem? Yeah, that’d be cool…
Justin is on the right track and i’ll agreee that i see some horrendous bike fits around the country at races - many bikes are too big for folks!
I’ll start by saying everyone is different and sizes can vary. I could ride a 51.5 cm TT (i’m 5’9") if i put a laid back post and a 100mm stem on the bike and get the effective length that i want. BUT … i know i want to ride closer to 76 degrees+ and know that a 54/55 cm TT & a 90-100mm stem while sitting a top a zero set back seatpost, with the seat centered on the rails should do the trick for me. (i know this from experience) … i also know i prefer a long narrow seat as i tend to move around a bunch!
My advice is start by knowing how steep you want to ride the bike and use that as your starting point. If you take a 76 degree bike, add a laid back post with seat knocked all the back you sure as heck have changed the angle at which you ride.
Hope that made sense and helped!
Slim,
According to the classical formula of inseam x .67 you would be on a 56. However, I’m your height and ride a 54 tri bike. My road bikes have varied from 53 (Lemond with long top tube) to a 57 classic Italian with a short top tube. 52 does seem like it might normally be a bit small for your height/inseam.
Unfortunately bike sizes are measured from the seat tube when in reality the top tube is the more important measurement. There is no formula to measure top tube and finding this optimum depends upon hamstring and low back flexibility as well as neck flexibility in a tri bike if planning on riding aggressive.
Worse yet, not all manufacturers use the same criteria for measuring. So a size 54 for example from company X may have totally different measurements from a size 54 from company Y.
To get three different recommendations on the same bike is a bit baffling. You’d think they’d be a little closer than that.
The question to ask is what bike are you looking at? People on the forum riding that model might be able to give you some idea based upon their measurements.
I went to the circus and stole a bike from one of the juggling bears, but it was still too big. So I emailed Ves and he hooked me up proper.
