“Half the Garmin team couldn’t enter their stats… I wonder where 90mm came from”
it came from me. i would need to see evidence that supports your statement above, unless you were being hyperbolic, which is fine. we’ll change it to some larger number. but i would guess the large majority of the garmin team has a saddle nose setback of less than 90mm. but it’s academic, we’ll change it.
the point of the ranges (we have ranges for all metrics) is to keep people from typos or the use of non-conforming denominations (imperial instead of metric, cm instead of mm, etc.). the reason this matters to us is we’ll use the data to determine where it is slowtwitchers are riding in the aggregate. if somebody says he’s riding with saddle height of 80 when he’s really riding with a height of 800 (all measures must be in mm) that 80 really throws off our averages.
You may be correct, it may not be half. I know they cannot use 3T Doric seatposts currently because they do not have enough offset. I know we had special seatposts made for the AR specifically for them as they needed 35mm offset posts on 73.1 degree frames and our own unique shape meant they had to come frome us. I know Trent Lowe has an offset of 11.4cm and his saddle height is only 741mm. I know many professional road riders use lots of rearward saddle offset to increase the amount of torque applied at low RPM for sustained climbs. I can’t say without looking over all of the fit data that it is exactly 1/2 of the team, but a substantial portion of them and the riders I know from road racing have more than 9cm. What do you think Lemond’s offset is? What about Indurain, Basso, Ullrich, Horner, Hampsten, Chechu…
These guys:
http://www.bikeforums.net/archive/index.php/t-80004.html
These guys:
http://weightweenies.starbike.com/forum/viewtopic.php?t=47745&start=0&postdays=0&postorder=asc&highlight=
I understand the need for correct numbers, using a drop down for units would help there, too; that way the metrically challenged can still use the system. I hardly think 92mm thows off your numbers as much as say your 80 vs. 800 example. Hey, I’m not so smart, I have no idea what it takes to get a database like the one your compiling together. I applaud your efforts.
Hey, I also get it’s roadie stuff, not particularly your cup of tea, I had only assumed I was making some error in my submission. Your show, your rules, I’ll just use 90mm.
-SD
