Bike cleaning (1)
I usually rinse off my bike and dry it off very well after almost every ride (3 times/wk) Is this too much? Do I risk messing up or rusting the components?
That might be a bit excessive. Several factors to remember: Always use a low pressure hose - you risk blasting grease out of bearings, hubs, BB’s etc… that way and that will accelerate wear and tear as well as diminish the ride quality. Another consideration is drying out the drive train, namely the chain or lubrication in the derailleurs. There are a ton of nook and crannies (for lack of a better term right now) on a bike, and it is impossible to get every square millimeter totally dry, so you also risk corrosion on cables, etc.
If you must clean it after every ride, I would just dampen a cloth and wipe it down - the frame, crank arms and fork.
Short Answer: Yes, that’s probably too much.
Happy riding.
Overkill.
Probably called for if you’ve ridden on wet roads or if you are talking about a mtn bike.
9 out of 10 cleanings should focus just on the chain and gears and dry weather road rides don’t necesitate cleanings more than bi-weekly.
Here’s a tip I learned from a teammate: Go buy a pack of furniture polish wipes (such as Pledge or something). When you get home from a ride that’s made you want to clean the bike up a bit, grab a wipe and go over the whole thing with it. When you’re done, hold the wipe in your hand and wrap it around the lower run of the chain and pull the chain through it by rotating the cranks backwards. This gets most of the attached grunge off of the outside of the chain as well.
This results in a really shiny frame and a fairly clean chain :slight_smile:
I save the “bike baths” for after riding in really grungy, wet conditions.
I’d say that is a bit excessive. I went to Target and bought a huge back of those synthetic rags. I use a damp one to wipe the bike down after every ride or two. When it gets a bit dirty, it gets demoted to drive train where I wipe the front crank area, rear cassette, derailleurs and chain. I almost never need to do a full washing. A clean, well oiled bike is a happy bike.
