Big Fantasy Football Draft tonight
The league has been together over 25 years.
Who was you super sleeper for this season???
Apparently I was sleeping…if you’d seen my team, you’d understand!
No real big sleepers that I’ve heard about this year. So much change in supporting casts that it’s tough to know who’s doing what.
Good luck.
last year I went with a new philosphy. Since the vertical game is so important now I went with a QB in the first round, then two stud WR’s, instead of the conventional RB first pick… Almost pulled it off. I think I’ll try again deppending on who’s available.
sleepers don’t win leagues
What position is your point system set up to favor?
TD’s are big, interceptions are a big penalty
If WRs get points per catch, they are the point getters…I didn’t realize it until after the draft in the last league I was in…only reason I lost
Bonuses for big yard days? Those don’t happen often but put Peterson, Brees, Rivers up a bit higher in the rankings
Typically its RB, QB, WR, then whoever.
Don’t go tight end crazy if people start drafting them…if there’s a good WR or RB still out there, then pick them up instead of the TE. There are only about 3 TE’s that set themselves apart from the rest.
Defense is whoever is playing the Dolphins or 49ers that week…
Pretty good draft-
QB - Schaub, Bradford
RB - Peterson, McFadden, Wells, Bush
WR - Calv Johnson, Welker, Britt, M. Thomas
TE Davis, Pettigrew
K Rackers, Succop
That is not so good of a team,
Ap, Calvin and Vernon are great,
Your qb’s are not great
Beanie sucks and bush too
Welker britt are never consistent
Good luck maybe everybody elses team looks like this too!
While not a sleeper I’m ranking ray rice higher this year. Ravens picked up the blocking FB from houston that helped their RB quite a bit, and they have Ricky W. to give Rice a break. I"d only rate A. Peterson higher.
Uh oh. Al Davis syndrome. Are you going to start calling in your own plays too?
