Bicycle Crank arm Shortening
Curious to get feedback regarding this crank modification. I wrote & received a reply.
Looking around on the web for other ideas to deal with a 1 " short right leg I came across your site. I currently use a 1" lift under my right shoe. This would be an alternative to replacing the right crank on several bikes with different bottom brackets.
The first increment hole is 24mm shorter, just shy of 1", so would work well.
Would this product work on a regular not recumbent bike? Yes, any bike
What crank length range does it work with? Any length.
I assume it goes into crank where the pedal goes. Yes. Does it weigh a lot? 154 grams per side.
Would the difference in weight make the pedaling lopsided? No
http://www.angletechcycles.com/accessories/CrankShorteners.jpghttp://www.angletechcycles.com/
I was relieved to see this was about bike parts…
Spot
Also, if you ever get attacked by a renegade ninja, you’ll be able to fight back!
:wink:
Jodi
ps. or am I the only one who thinks these look like weapons?..
It does look like it would make the Q-factor on that side a bit wider-maybe not enough to matter much, but perhaps noticeable.
