Best tubular tires for HED stinger 60(front), 90(rear)
I’m working on getting my bike ready for my IM coming up. I want to throw some new tires on it. What are the best tubular tires for HED stingers 60/90?
I’d contact HED to see what they’ve tested in the tunnel. At the moment, I’m running Schwalbe Ironman tubular 22mm front and rear and I’m quite happy with them. I’ll probably swap the rear to a 24mm Schwalbe One before Lifetime Chicago for a bit more comfort.
Do they have a removable valve core?
I run the 22/24 (not on HED) and yes they have removable core.
Wait… they make the ironman in a 24?
No , I ride what you suggested you might do.
conti comp. their 22 is wider than most 23’s
corsa evos are good as well
I’ve got a Stinger 6 front with the 22mm Ironman. Faaaast!!
AA - How many front wheels have you had this year?!?
Haha!! Well, the Easton was the original wheel. But then I went back to my old clincher when I struggled with my bike handling abilities. But then went and started to use my lady’s old Stinger when I needed some funds and sold that clincher.
…I have a wheel commitment problem.
I have HED Stinger’s; same wheel set as you. These rims are very wide for a reason.
Conti Comp 25MM is what I run.
