Best Tubular tire for the C2 rim
My Jet disc is in, and I need to put some rubber on it and test it out. What did ST decide was the best size tire and brand for the C2 rim? I thought a 23 worked best but then I found the post on the bontrager tires and I think people were running 21mm tires?
If you have a HED C2 tubular rim, especially a Jet disc, what tire are you using? thanks!
bumpity bump
I also just ordered a H3 tri-spoke and a Stinger tubular disc. I’m curious the same question (& for tubulars). Thanks
Andy from Trek indicated that the Jet Disc shown in the interactive drag charts was a C2 tubular wheel with a Vittoria CX 21 tire. The width of the CX 21 is about the same as the Bonty RXL Pro tubular but the Bonty rolls a bit better when I tested them. Both have very similar profiles. I have a Bonty RXL Pro on a Jet Disc tubular C2 and it fits fairly well. Can’t comment on the CX 23 fit although it’s really not much wider than the CX 21 (RXL Pro ~ 21.7 mm, CX 21 ~ 21.5 mm, CX 23 ~ 22.5 mm).
Thanks! That’s exactly what I was looking for. I knew I had read a post on here with a definitive answer, but I didn’t find it when searching. Thanks again.
The Vittoria CX 21’s are a great choice for these tubulars. Andy was correct in saying this regarding these tires. a 23cc will work well on the back tire as well since the sizing is so minimally different. Vittorias have been hard to get as of late along with Conti Competitions (another tire that works well here). The Bontrager Race X-Lite is the similar tire to the Vittoria. The Bontrager XXX Lite is produced by a different company but will work well with these wheels as well. 23’s mate up well with the wider 23mm C2 rim. Since the rim wells run deep (as you have probably already noticed) the tire, any tire, will sit deeper and actually spread laterally a bit. This stiffens the sidewall up a bit since the tire is not standing as tall above the rim. Plus, you will never have such as easy time rolling a tubular on and be assured that it will stay on. I have run these wheels through the paces with no problems. Enjoy!
Recognize your name from the StarTribune article…how did the state TT go? And what wheel set-up did you use?
