I currently have two below saddle mounted water bottle cages on an x lab super wing, I also have a speedfill that is frame mounted with a straw tube. I am looking to get a new hydration set up as my water bottles tend to fall out at higher speeds and the frame mounted speedfill is getting old.
What is the best hydration set up?
Please help!!
Please help!!
At the risk of sounding like a smartass, Shiv integrated bladder. I’ve tried just about everything else. Shiv bladder, plus a bottle cage for an extra bottle, which I then pour into the bladder when it’s empty, and get another bottle if I need to. (Decent bike handling skills are needed…) For other bikes, bottle or aerodrink between handlebars.
I’ve never ever had water bottles fall out. Bend the cages a little so they hold the bottles a little tighter. Or get new cages.
I’ve never used xlab type behind-saddle hydration. Bottles tend to fall out of those a little too easily.
Bottles should not be falling out or launching on a rear carrier, whether it be single or dual bottle carrier. There are 3 things to consider if this happens: 1. Type of bottles using, 2. the type of cages used, 3. the angle of the cages/carrier.
Would love to help you on your setup!
Candice - I have had the same issue as Gilbert, the number of bottles I have lost during a race can’t even be measured. I do love my x lab wing, but I am not sure it is set up correctly and I have the right cages on there.
I would love your advice on this as I think x lab makes a great product.
Well would love to help you! Would need a side view picture of your setup. You can post it on here or email me directly at candice@xlab-usa.com.
I’ve tried a few set-ups. My favorite is an xlab torpedo between the aerobars. I went with the “refill upgrade” kit; which consists of everything but the mount-cage. I started with a regular bottle cage zip-tied between the aerobars and the torpedo fit fine. Then I tried no cage at all. I just use a velcro strap and the torpedo fits perfectly snug laying right on the aerobars. No bounce and no splashing. Granted, my bars are close enough together to make this feasible. When I need more liquid I have an Arundel Chrono II on my seatpost.
