I am looking for recommendations for a good training place in April, within a 5-6 hour flight from Germany. We are registered for UTÖ SWIMRUN and need a good place to practice trail runs, transitions and swimming in our running shoes. Any ideas? Thanks!
The German triathlon scene forum is doin a tri camp in Mallorca from 12th-26th of April. The info is in German only as far as I ve seen quickly. If you want a contact let me know and I’ll find out.
Lanzarote. Velvety roads? Which bit have you been riding on? I nearly lost my fillings last time I was out there. The main road from the bottom of Tabayesco is about the only velvet I found!
Consider Playa del Muro in Mallorca, excellent facility, bike rental plus 25m indoor pool. Also T3 Top Training Teneriffe is an option. Finally if you want mountains check out Andalusia (veloandaluz.com)
Majorca will be a couple of degrees cooler but the training conditions will be better due to minimal wind. I would consider Port De Pollensa, the hotel below has a 25m swimming pool and is right on the sea front. You can swim safely in the sea or in the pool. There are trail runs close by.
In April Mallorca can be a bit cold for swimming if unlucky.
Well, the race Utö swimrun can be pretty cold as well so if the plan is to do as racelike training as
possible, the watertemp in Mallorca probably not gonna be a issue
