Best deal on 07 Chorus UT compact?
I’m seeing $350 without cups on eBay.
Anything cheaper than that out there?
For good measure:
http://westernbikeworks.com/Images400x267/CACCU-1.jpg
http://images.google.com/images?q=tbn:Syi3d5G4lgL45M:http://www.totalcycling.com/ProductImages/1245.jpg
http://www.cyclingnews.com/photos/2006/tech/features/campaggroups2007/picture2tn.jpghttp://www.cyclingnews.com/photos/2006/tech/features/campaggroups2007/picture6tn.jpghttp://www.cyclingnews.com/photos/2006/tech/features/campaggroups2007/picture7tn.jpg
I suggest getting them at your LBS. That way when you notice you dont have the tool to install the cups, nor the proper fittings for the torque wrench for the 10mm center bolt, nor know how to get the installation spring out of the drive side - they will help you.
Sounds like that comes from experience.
But, LBS = $450 + labor.
Internet = $350 + labor @ LBS.
Seems like $100 is saved by buying on the internet. That’s assuming they’ll charge for the install either way, which I’m sure they will.
and if your LBS is anything like mine, they’d have to order them anyway.
True story. The LBS will put them on either way, it’s just a question of whether I’ll hand them $100 extra markup as foreplay.
…and chances are they see little of that $100 anyway since their supplier won’t cut them a break ordering one crankset. On stuff like this, I usually wait for a good c-bike across the board sale. My record skeletons were $205 (from $270).
Go to your LBS and ask them if they have any spare DuraAce wrenches for the BB. Most shops will have 50 of them all over hell as they get one with each crankset, and dont give them to the customers. That will take care of the cups.
Go get a 10mm 3/8" socket from Sears and have a 2" 3/8 extension for your torque wrench.
Use a needle nose vise grip to get the spring clip off of the BB shell once your arms are installed.
Have a blast getting to the super high torque if you dont have an assistant (42ft/lbs if I recall)
RE TORQUE the BB after a few hours of riding!!!
Thanks, sounds like just enough info to be dangerous. I’ll let you know how it goes.
